Author Topic: afr/wideband goals?  (Read 2089 times)
dgdogz
afr/wideband goals?
« on: 17:04, Tue 04 November 2008 »
well all the raffling ive been doing bout a wideband and now im gona buy one and get my wee mate to weld in the bung but
what should i be doing when i get it.
i know it all changes in diff gears and what not.
but what sort of figures shld i be aiming for.
does it depend on what power ur lookin to run and what turbo to have or??
cheers
ddddddddddddddddddd
« Reply #1 on: 17:30, Tue 04 November 2008 »
You want to aim for 11.9-12.4 @ WOT at the highest RPMS you go to.
ie: if you revved to 6500 rpms  the highest you want to see is 12.4 @ 6500rpms, cars make good power between 12.1-12.4 on carbs... idle around 14-14.7 but it should hold steady around what you set it at, say you set it to 14.5, it should only fluctuate to within +/- 2 points max.
dgdogz
« Reply #2 on: 21:50, Tue 04 November 2008 »
i get wt ur sayin hopefuly
hahaha
jus one thing what is WOT?
 :oops:
jus in advance what wld i do if it idles way to high rich or lean?
obv apart from adjstin the mixture is ther a underlyin problem tht cld b causin it?
thanks steve
d
« Reply #3 on: 21:56, Tue 04 November 2008 »
Sorry, can you translate from the jibberish above please, i don't do txt spk on d 4rum m8 ;)
Seriously though WOT = Wide Open Throttle.
If it won't hold idle then yes you need to look for air leaks etc.
& less txt spk please ;)
I let the odd abreviation slip but it's getting quite bad now.. not just you though.
Cheers
Scrooge L  :wink:
dgdogz
« Reply #4 on: 15:49, Wed 05 November 2008 »
hey ho
thanks for the heads up on the WOT abbreviiation.
the car does hold idle but what sort of a/f numbers should be readin on the gauge
cheerrrrrrrssssssssss
« Reply #5 on: 16:57, Wed 05 November 2008 »
Quote from: "5teve L"
dgdogz
« Reply #6 on: 20:05, Wed 05 November 2008 »
cheers for tht..
too busy wi lookin at other things
haha
