Author Topic: R5 cup car spec  (Read 1143 times)
Stealthgrow
R5 cup car spec
« on: 14:13, Fri 31 October 2008 »
does anyone know the fulll engine spec of the r5 cup cars?
Re: R5 cup car spec
« Reply #1 on: 15:03, Fri 31 October 2008 »
Quote from: "Stealthgrow"
It's the same engine as a normal GTT apart from a genuine Group A carb (150 main, 27mm Venturi, Brass enlarged Aux Venturi and a .9 a/c), Devil strut brace, Devil side exit exhaust, 1bar boost (Actuator set), TDC wire swap (Advances ignition), coolant system modified (HEader tank located in scuttle area), Intercooler has more cowling to direct air through it better.
Billiam
« Reply #2 on: 18:03, Sat 01 November 2008 »
They used standard 25mm carb's.
Here's the low-down:
http://membres.lycos.fr/r5gt/gtt/cup.htm
Been around these cars for too damn long!
