hi there i have had this problem on my r5, and i was told to check the connections by the gear box, but that was okay, in the end it was the connection plug, it was full of water, so i dried it out and sprayed it with wd 40, and my speedo woks fine, so its time to hook up the heads up display, try the plug and see if you get a result you never know with these cars
