Welcome,
Guest
. Please
login
or
register
03:08, Wed 10 August 2022
Home
Help
Search
Login
Register
TECHNICAL ISSUES
Renault 5 GT Turbo
would these fit my 5??
« previous
next »
Print
Pages: [
1
2
Author
Topic: would these fit my 5?? (Read 3989 times)
dgdogz
200BHP Senior Member
on:
18:41, Tue 19 August 2008 »
http://www.borbet.co.uk/a.htm
would these fit??/
i really like them
d
Logged
www.ecossecarclub.co.uk
Global Moderator
Reply #1 on:
18:44, Tue 19 August 2008 »
Because of the width they might scrub on the rear arches, depends how low and stiff you go i suppose.
Logged
Test
Global Moderator
Reply #2 on:
18:49, Tue 19 August 2008 »
All depends on the ET and stud fitment aswell matey width wise 7.5 may be the max you could go may possibly rub
Logged
dgdogz
Reply #3 on:
18:52, Tue 19 August 2008 »
what about with spacers???
new pic
Logged
Test
Global Moderator
Reply #4 on:
19:02, Tue 19 August 2008 »
As said what ET fitmet are they and stud pattern. If you put spacers on that will push them out to the arch (Which you could always skim the arch / sand / file it down so no rubbing on that side).
Logged
Reply #5 on:
21:56, Tue 19 August 2008 »
They won't fit under standard arch. I tried....
Also, this one on you pic is 9" wide which is out of league for any french car.
Logged
dgdogz
Reply #6 on:
14:30, Wed 20 August 2008 »
but thy will fit???
the 7.5 inch??/
d
Logged
Reply #7 on:
15:49, Wed 20 August 2008 »
Yes. 7.5 will fit without problem. If car is lowered more than 50mm watch out that ET is around 40 :wink:
Probably, this kind of rim has ET 25 to 15 but you can grind off "extra" 15-20mm
Logged
dgdogz
Reply #8 on:
16:41, Wed 20 August 2008 »
thank you
im gona look into gettin these asap
i think ther really cool
d
Logged
Reply #9 on:
20:28, Wed 20 August 2008 »
Yeah, they really look nice. My suggestion is to buy them with de-badged central cap
Logged
dgdogz
Reply #10 on:
21:24, Wed 20 August 2008 »
what is ET???
Logged
Reply #11 on:
11:53, Thu 21 August 2008 »
Well you know the price mate ive got you agood discount on them let me know anytime
7.5x16 195/45/16
£ cheaper then anywhere else
Logged
Reply #12 on:
16:46, Thu 21 August 2008 »
Quote from: "dgdogz"
what is ET???
ET is the number that shows how much mm central hub of the wheel is "inside" the wheel comparing to outer center. For example if you ET is 40 that means that central hub is 4cm inside the wheel...
Larger ET gives you more space under the arch and you can fir wider rims.
Logged
dgdogz
Reply #13 on:
09:01, Fri 22 August 2008 »
so et is the inside of the rim width???
or am i wrong??
Logged
smudger
Reply #14 on:
09:12, Fri 22 August 2008 »
This is making my head hurt. It's far too confusing for me :lol:
Logged
Print
Pages: [
1
2
« previous
next »
TECHNICAL ISSUES
Renault 5 GT Turbo
