Author Topic: Forge FMIC !!!!!!!!!! and which turbo!!!!!!!!!!!  (Read 5605 times)
« Reply #15 on: 18:31, Fri 11 July 2008 »
Quote from: "PHASEONE"
How much are the fmic's from forge?
http://www.forgemotorsport.co.uk/conten ... t=FMINTR5T
« Reply #16 on: 18:45, Fri 11 July 2008 »
right after a bit of debate iam going to go for a T28 and a Forge FMIC and go for 200bhp as iam sure with myengine spec 200bhp can be gained
PHASEONE
« Reply #17 on: 18:55, Fri 11 July 2008 »
£430! ouch! is there any cheaper alternative's? for example the vw boys often use a mercedes sprinter fmic . just a thought
« Reply #18 on: 19:05, Fri 11 July 2008 »
there is plenty of universal ones on ebay which iam sure you could fit somehow and it would just be a case of making somepipe work up
NaylsGTT
« Reply #19 on: 19:26, Fri 11 July 2008 »
This setup cost me less than £180,that includes a custom made alloy carb top.
« Reply #20 on: 19:30, Fri 11 July 2008 »
Quote from: "NaylsGTT"
interesting, got me thinking now
« Reply #21 on: 08:23, Sun 13 July 2008 »
think iam going to go for the grille mounted option now for a intercooler as dont want to chop standard bumper up really and i think it will get more air behind grille and keep it looking like this
NaylsGTT
« Reply #22 on: 10:35, Sun 13 July 2008 »
Quote from: "dazzleandshine"
Yeah definitelty mate, slightly shorter boost run too :)
i have an aj tuning bumper so my cooler would get more air flow from being in the bumper really,but i prefer the grille option.
if im going out to race i'l just pop the grille off
« Reply #23 on: 11:14, Sun 13 July 2008 »
yep i think its the way forward now so looking on ebay now to try and find a intercooler which will fit behind grille and in front of radiator with out being to tight
Arturas-zender
    • http://www.emusic.lt
« Reply #24 on: 15:41, Sun 13 July 2008 »
Hey Steve , what turbo would you suggest me ? Now I have T3 and it is very laggy.. It comes on full boost at 4.5-5k rpm...Ofcourse ,it kicks very well , but my car is for road use (not planning to have more than 200bhp) , so I would like to have very quick spool , at low rpm's , but to try not to lose torque at highs. I am thinking about something like KTR 250 ROLLERBEARING POWER SYSTEM HYBRID TURBO , but the price is a bit high  :)  what do you think about it?  :wink:
Thanks for any suggestions.
Sorry for my english...  :oops:
« Reply #25 on: 16:09, Sun 13 July 2008 »
I can get a roller bearing T28 for £910+ postage, or something like the T25 with .49 rear will do, like i have now ;), this is £520 new or i'm thinking of selling mine soon to upgrade to a T28 as i use mine for drag racing, keep an eye on the for sale section.
Here is a price list, you would have to add postage to any of these prices.
T25 with .47 rear, good for 180bhp, maybe more depending on engine spec £450 (this turbo is closer to the KTR 230 than the 180 as the 180 runs a bored out .35 T2 rear housing ) 55 trim comp wheel
T25 with .49 rear 225 bhp £520 60 trim comp wheel
T28 with .49 rear 260bhp £620 50 or 60 trim comp wheel
T28 rollerbearing 280bhp £910
NaylsGTT
« Reply #26 on: 17:49, Sun 13 July 2008 »
you'l have to push the rad towards the engine like i have unless you find a slim intercooler,
also when you measure up,dont forget about the silicone bend's you'l be adding that will make it wider still.
if you can find one,i'd get a cooler with the inlet facing towards the turbo,you'l have little bit more room then :)
« Reply #27 on: 21:58, Sun 13 July 2008 »
cheers for info iam going to get tape measure out tom and take grille of and have a nosy and see what i can come up with
