Author Topic: speedo problem  (Read 3500 times)
jaxc khan
speedo problem
« on: 18:10, Fri 04 July 2008 »
hi there i was woundering if any one could may be help me, my speedo dosent work on my car all the other gauges work, i cant seem to get to the senser in the engine bay, what i was woundering was  could i fit in a cable run speedo as i found the place where it gose it was coverd by a rubber grommet, i would be gratefull if some one who has done this conversion before, and dose any one know if the phase ones are cable or electric, thanks
too fast for scoobys
lexgtturbo
« Reply #1 on: 18:37, Fri 04 July 2008 »
phase one has an electric one.
dgdogz
« Reply #2 on: 16:01, Sun 06 July 2008 »
ive got the same problem too
ive got an 89 phase 2 i think....any ideas on how to fix it or what it could be???
thnks
d
tenby05
« Reply #3 on: 16:05, Sun 06 July 2008 »
mine dont work either phase2 1990 :?
« Reply #4 on: 16:08, Sun 06 July 2008 »
Check the connection by the air filter first, the sensor cable is grey and theres a black plug clipped onto the bracket for the original airbox.
tenby05
« Reply #5 on: 16:15, Sun 06 July 2008 »
i cleaned mine before and still nothing :cry:
« Reply #6 on: 17:47, Sun 06 July 2008 »
if failing that cleaning the connections has'nt worked check the speedo sensor in the gearbox
« Reply #7 on: 22:00, Sun 06 July 2008 »
Also the actual gauges themselves fail.  :roll:
« Reply #8 on: 16:15, Mon 07 July 2008 »
on my phase 1 the connection on the gear box pops out, i think there's supposed to be a retaining clip for it. you might be having the same problem as me?
« Reply #9 on: 17:38, Mon 07 July 2008 »
mine always plays up so ive just given up with it now and use my sat nav so i no how fast iam going :lol:
« Reply #10 on: 17:44, Mon 07 July 2008 »
Good way of keeping the mileage low.  8)
« Reply #11 on: 18:09, Mon 07 July 2008 »
your right there is ment to be a clip holding it in
« Reply #12 on: 18:11, Mon 07 July 2008 »
Quote from: "smithsgtt"
cool, cheers for that. i'll have to sort one out  :D
jaxc khan
speedo
« Reply #13 on: 20:03, Mon 07 July 2008 »
i have checked the cilp and its okay, the senser is very hard to get to so i was woundering if i could convert it to a cabel one, was woundiring if any one had ever done it
« Reply #14 on: 21:01, Mon 07 July 2008 »
i never heard of it . ive heard that people have changed there box then gone to cable
