Author Topic: fan switch relay  (Read 3183 times)
PHASEONE
fan switch relay
« on: 21:45, Wed 02 July 2008 »
where can i get a fan switch relay for my phase 1 ? cheers
« Reply #1 on: 22:56, Wed 02 July 2008 »
renault still do some relays. or try cgb?
or you could put it on a manual switch, a lot of people are highly against it as you can forget to switch it on.
mat_pithers
« Reply #2 on: 23:03, Wed 02 July 2008 »
u can get them from renault for 18
baysidecustoms body shop tell: 01227372868
« Reply #3 on: 08:55, Thu 03 July 2008 »
if you do put it on a switch remember to turn it of when you leave car as i forgot a couple of weeks ago and come out of mates house and had a flat battery :lol:
« Reply #4 on: 09:07, Thu 03 July 2008 »
wire it up so when you switch the ignition on it comes on then its running all the time and you'll never forget to switch it on.
PHASEONE
« Reply #5 on: 17:46, Thu 03 July 2008 »
great thanks i,ll try renault as for the switch idea i would def either leave it on or forget to turn it on cheers
« Reply #6 on: 18:07, Thu 03 July 2008 »
GSF Carparts sell them aswell
jamie
« Reply #7 on: 19:42, Thu 03 July 2008 »
it is a standard relay, take the one you have to any car place and match up the diagram on the top  :D
spinney spinney drinkey drinkey
vulpyfox
« Reply #8 on: 23:01, Thu 03 July 2008 »
I just got an original used working one from CGB motorsport for 5  posted to my door ^.^ [any 25 amp relay of the same type will do] but if you still have the round rubber bung on the relay socket try and get the original part ^.^
^^vulpyfox^^
PHASEONE
« Reply #9 on: 21:14, Fri 04 July 2008 »
Quote
Cheers i tried gsf today i swear the one by me is run by complete numpties you can get a piece of engine tin ware for a 50 year old vw  but ask for any thing French!?
Yes i do have the original rubber sleeve so i'll try renault many thanks
vulpyfox
« Reply #10 on: 22:13, Fri 04 July 2008 »
try CGB motorsport they got me one used but tested original part for 5 its alot cheaper than 18 from the main dealers !
^.^ and yes GSF do tend to hire magic ppl sometimes hehe well the luton branch is ok but again they favor the german more than the swedish and french
^^vulpyfox^^
Phase I 16 V Turbo
  • Trusted Trader
    • http://www.gt-turbo-spares.co.uk
Relay
« Reply #11 on: 17:49, Fri 11 July 2008 »
You can pick them up for 3 -5  new from most auto factors, just check the pin outs.
