Author Topic: FRESH R5 OWNER  (Read 2997 times)
dgdogz
FRESH R5 OWNER
« on: 17:05, Sat 10 May 2008 »
hey ppol
im a young and fairly amateur arrival to this r5 scene
looking to go whole way tho
any help or tips hints ,,,maybe even fellow owners in the scotland (glasgow area) would b good
take care
peaceeeeeeeeeeeeeeeeeeeee :D  :D
gjb0535
« Reply #1 on: 18:05, Sat 10 May 2008 »
Hi and welcome
Good forum for R5 turbo info and advice. For spare parts etc some of the sites I use apart from ebay are
http://www.k-tecracing.com/
http://www.cgbmotorsport.com/
Other people on this site may have other sources to advise on.
Im a fellow Scotsman from Fife
dgdogz
hey hey scottish r5 takeover hahaha
« Reply #2 on: 14:13, Sun 11 May 2008 »
hey hey
how u doin
thanks for the sites
ive checked them out alrerady
some bits and pieces on my shopping list hahaa
im so skint already
u kno of any place to go for a good tune up
closest to glasgow as possible???
d
« Reply #3 on: 14:29, Sun 11 May 2008 »
hi and welcome. near glasgow that knows about the r5gtts you might be luck but you would need to search every1 ive never heard of any in glasgow all the 5 owners take there cars to mike at pcs in kinglassie fife
« Reply #4 on: 14:31, Sun 11 May 2008 »
Hi welcome to the forum.
Don't forget GSF www.gsfcarparts.com
Also don't be fooled by tuners saying uprated parts are better than standard it's not always the case i.e. copper core rad is a no no and the uprated starters will work but will not work for long and other parts can be purchased else where cheaper for the something.
dgdogz
« Reply #5 on: 15:36, Sun 11 May 2008 »
cheers ppollllllllllll
need all th help i cn gt
 :D
gjb0535
« Reply #6 on: 18:54, Sun 11 May 2008 »
I dont know of anyone who does Gt  in central Scotland apart from PCS.
Regarding the tune up if standard spec it is fairly easy to DIY. A haynes manual is useful to have. To start you could change the spark plugs fuel and oil and air filters.
The ignition timing is non adjustable. I.e you dont have to check and adjust it with a timing light as per some other 80s cars. As per modding the ignition system can be tweaked other posts will explain this in detail.
If you have access to a co gas meter you could set up the carb (idle speed and mixture co)
If you are unable to set the car up as per manufacturers settings then further exploration will be required. Some of the things you might have to consider is overhauling the carb checking all breather hoses for leaks etc.. A carb gasket kit will set you back about 20.
From then on if the car still isnt running right the other posts on this forum can advise on what to do.
Again if the car is std normal DIY servicing and tuning might be all you need to do. If modded then specialist tuning such as a rolling road tune might help, other posts will advise this.
Im sure other folk can offer more advice
Hope this helps
whooosh
« Reply #7 on: 23:22, Sun 11 May 2008 »
Quote
why is this?
turbo whine is mighty fine
« Reply #8 on: 07:08, Mon 12 May 2008 »
fit like,welcome to the forum mate :D
dgdogz
« Reply #9 on: 15:51, Mon 12 May 2008 »
cheers lads
i guess itll be a lil trip to fife then
hahaha
i got all the usual suspect issues done
replaced header tank,oil,oil filter,spark plug change
and i fitted viper kit
baught a new turbo the other day and got new carb lobster elbow(think its called plenum)
so ill fit the plenum myself ...seems easy enough
and im gona buy t3 actuator from k-tec tomoro...aswell as low temp thermo and thermo switch coz im gettin some overheating issues.
but soonnnnnnnn enuf.
 :D
