Author Topic: HELP this is my first attempt at a scrabble wagon  (Read 2635 times)
Fudi
« on: 19:33, Tue 25 March 2008 »
hi guys
me and my mate are away to buy a 5 to do up i've got a few q's though
it currently runs this spec
fox 15" alloy wheels
full magnex s/s exhaust
gp a carb
stage 2 head
uprated headgasket
k tec double capacity alloy intercooler
gt tuning alloy carb top
gt tuning spider valve
gt tuning in car boost (not fitted)
samco boost hoses in red
chrome rocker cover
high output alternator
uprated fuel pump
tinted rear windows
tinted front indicators
clifford concept 50 alarm and imob with certificate
35mm lowering springs
my mate has a t16 off a rover coupe will this bolt on if so what power output is it gonna be at?
Fudi
« Reply #1 on: 23:54, Tue 25 March 2008 »
anyone ?
Whats everyones recomendations for an engine spec for a reliable 150-160 BHP that'll spool nice and early and is ideal for back roads?
« Reply #2 on: 00:59, Wed 26 March 2008 »
Quote from: "Fudi"
anyone ?
The spec above is more than capable for 160bhp.  Its good to see you looking for a sensible figure thats going to stay reliable and still a good fast toy.  The standard turbo (T2) will be ok for 16psi..  that will get you to 150- 160bhp with the fastest spool up.  Anymore than that psi and you'll want to look at a T2/T25 or full T25..but u'll get a bit more lag.. and get you to around 180bhp or more depending how far u wind the boost.
 Any pics of the car?
Fudi
« Reply #3 on: 01:14, Wed 26 March 2008 »
not yet mate they'll come on sunday lol
so if i look for a t2 or 25 then it should be reliable enough with good maintenance?
what about the tomcat turbo are they t16's ? just asking cause i have one o them lying about ?
EDIT * just realised that this car is cavsri130's car he has for sale dont worry mate we're coming*
NaylsGTT
« Reply #4 on: 10:20, Wed 26 March 2008 »
tomcat turbo's are t25's mate,16psi would be a sensible limit on them,it wont just bolt straight on though.
Fudi
« Reply #5 on: 21:34, Wed 26 March 2008 »
cool i have a couple t25's then (standard fit on my s13)
Whats required to get a t25 on the 5 then ?
Also i now realise they use carbs is there and ecu on the engine if so what does it require to be able to run at above powers etc
Sorry to sound like a noob guys but my mates dumped me in at the deep end and im trying to surface asap to get this car roaded !
« Reply #6 on: 08:51, Thu 27 March 2008 »
The 'body' of the turbo needs to be rotated so the oil feed is on top, mine was facing towards the passenger inner arch.
Will probably need adaptors for the oil feed and oil return.
Thats for the T25 that comes off a Rover, not sure if the Nissan ones are the same.
Fudi
« Reply #7 on: 21:24, Thu 27 March 2008 »
ok cool i have a rover one so all is good that aint no biggy changing that :)
any help on the management issue?
« Reply #8 on: 08:31, Fri 28 March 2008 »
All you need to do is play with the carb jets, have a look in the DIY section theres a detailed post about it.  8)
Fudi
« Reply #9 on: 17:24, Fri 28 March 2008 »
Ace cheers mate  :D
