hey phase 2 tungy,cheers mate ,i know had a we got with the buff ,will go with the chrome under the bonnet :lol:
yes i did drill the standard one from 1.7 to 1.9,i cleaned it out and then check for it sealing there was a small leak so all i did was turn it over and gave it a tap until it sealed as the needle is brass too and it worked no problem ,not sure if i would be so lucky if i had to drill it to 2.0mm,
the second stage drilled no problem either thank good ,didnt want to damage it or drill too much either,so once i get back from offshore im gonna get it on and see what its like,ive got a t28 to go on to in the procees of putting it back together ,and then get her set up and see what the figures are
