Author Topic: door speakers  (Read 8522 times)
joshcampus
door speakers
« on: 22:48, Sat 20 October 2007 »
what size speaker can i fit into the front doors of my r5. I removed the door card and noticed speaker holes.
Also how easy are the speakers to wire up if i had to start from scratch.
thanks 4 now josh
Goran
    • http://www.bhrenaultclub.com
« Reply #1 on: 18:48, Sun 21 October 2007 »
Door speakers' size is 13cm (5 inches)... :wink:
frog
Re: door speakers
« Reply #2 on: 19:13, Sun 21 October 2007 »
Quote from: "joshcampus"
Speakers are easy enough to do. Simply run 2 wires from your stereo to the position you want the speakers and bingo.
Most stereos have 4 speaker output so make sure you run front left to front left, etc etc
lexgtturbo
« Reply #3 on: 20:30, Tue 27 May 2008 »
Its pretty easy to use 6,5" sets ive got a 6,5" pioneer set with separate tweeters. The only problem using these sets are that the window can hit the speakers magnet. To avoid that from happening, fill the speaker hole in the doorcard, using fibre glass. Then cut a hole with a tight fit for the speaker. Then mount the spaekers in the doorcard, and Tadaa... good enough clearing  :D
Also if you choose an expensive component set, use a good amp to power them. Only way to get it better than this is more speakers  8)
whooosh
« Reply #4 on: 22:56, Tue 27 May 2008 »
best way to fit larger door speakers is to make some spacers out of mdf, then screw the spacer to the door and screw the speaker to the mdf. this will give you a good solid mount for the speaker and thus give you a much better,crisper,deeper sound 8)  :wink:
turbo whine is mighty fine
« Reply #5 on: 12:52, Wed 28 May 2008 »
Quote from: "whooosh"
thats what ive have done with mine
lexgtturbo
« Reply #6 on: 21:19, Thu 29 May 2008 »
and possibly what i have to do next... good idea
DJLOG
    • http://www.myspace.com/djlog
« Reply #7 on: 03:06, Tue 16 December 2008 »
I've just fitted Mutant 3 way 6x9's in the rear parcel shelf and I'm wondering what to put up front now...... I'd like to put some Pioneer 13cm ones in the doors, to match my head unit, don't think I can afford a component set at the minute, (plus this is my first ICE install) do I go for....
normal/dual cone?
2 way?
or 3 way to match the rear set?
I still need to pick up a 12" sub and amp for the boot
cheers 8)
whooosh
« Reply #8 on: 08:55, Sun 04 January 2009 »
go for components if poss, you will be supprised how cheap you can get them for .  halfords are doing some good deals or have a look on the net. go for the best you can afford  :)
DJLOG
« Reply #9 on: 01:25, Mon 05 January 2009 »
Mint mate, cheers for the reply  :)
Might invest in these little beauties:
http://www.halfords.com/webapp/wcs/stor ... yId_165707
