Author Topic: greetins  (Read 1614 times)
solinakias5gtt
greetins
« on: 10:40, Sun 15 November 2015 »
hello to all the members and concragulations for your site.i am the owner of a 5 gtt the last 17 years and now i have my 4th 5 gtt.
i would like little help with afr problem i have.i have just finished my rebuild on c1j and until 3.000 rpm everything is ok.when i push the pedal and the turbo comes in i feel the engine hezitating and i see on the wide band afr 16-17.all these with t-2.5 and std engine @1.0 bar presure.i turn of the turbo pressure @ 0.8 and still i have afr 14/15
my carb is std with 120 main jet 100a/c 100first stage and normal 2nd stage.
i now these numbers of jet are ok for std engine but something on my mind for frp issue.today i will try  another carb i have with 2n stage 1.4 opened and i will informe.
always any opinions are wellcomed. sorry for my rusty english ,
solinakias5gtt
Re: greetins
« Reply #1 on: 10:46, Sun 15 November 2015 »
i managed to fit my second carb on my car
specs 120 main jet
          0.9a/c
          100 first stage
          1.4 second stage
          1.9 niddle
the car now boosts up to 18 psi and my afr of boost is 10.8 and with wot i see 11.1.logical my fpr works normal
i think is still to rich i will try to put 1.0 a/c and see new numbers.
i would like to ask how much lean maximum  should i run on wot and if its worthing to invert the cables of my tdc sensor to gain some avans ?
thanks 4 your time
turbak
Re: greetins
« Reply #2 on: 13:15, Sat 27 August 2016 »
Its worth  :)
