Author Topic: Timing scatter  (Read 1864 times)
STEW
Timing scatter
« on: 01:56, Thu 24 September 2015 »
Hi everyone. I have a 5 turbo here which has the ignition bouncing all over the place. When I gently tap the module the ignition moves . Can any one help me please?
STEW
Re: Timing scatter
« Reply #1 on: 09:38, Wed 30 September 2015 »
No one? Does any one have a suggestion for options on the RE209 replacement or repair, please?
STEW
Re: Timing scatter
« Reply #2 on: 01:26, Sun 08 November 2015 »
Problem solved using Trigger wheels megajolt system. Thanks for the interest. Vehicle goes very well at 7 psi in the manifold. Starts without choke and idles well.The timing chain is stretched so will be retiming the camshaft in the future.
As it is the boost starts spooling at 1500 with 6 psi by 1800. Not a bad little rocket.
