Author Topic: engine dropping revs  (Read 2370 times)
foxterier
« on: 16:44, Sun 20 September 2015 »
Hallo guys
My r5 doesn't hold the revs constant when idle. It drops them significantly when cooling fan kicks in. Is it electrical problem: cooling fan, ECU,  anything else?  Many thanks
Re: engine dropping revs
« Reply #1 on: 20:17, Wed 23 September 2015 »
What does the car idle at RPM wise normally??
Sounds like the idle screw needs setting with a couple of electical item's on.
The R5 is basic it doesn't have an ECU it has an AEI unit which has a very basic ingition map on and that is it.
turbak
« Reply #2 on: 13:24, Sat 27 August 2016 »
Ita normal when the fan start to work...
