Welcome,
Guest
. Please
login
or
register
02:02, Tue 09 August 2022
Home
Help
Search
Login
Register
RENAULT5GTTURBO.COM
TECHNICAL ISSUES
Renault 5 GT Turbo
engine dropping revs
« previous
next »
Print
Pages: [
1
Author
Topic: engine dropping revs (Read 2368 times)
foxterier
115BHP Newbie
on:
16:44, Sun 20 September 2015 »
Hallo guys
My r5 doesn't hold the revs constant when idle. It drops them significantly when cooling fan kicks in. Is it electrical problem: cooling fan, ECU, anything else? Many thanks
Logged
Test
Global Moderator
200BHP Senior Member
Re: engine dropping revs
Reply #1 on:
20:17, Wed 23 September 2015 »
What does the car idle at RPM wise normally??
Sounds like the idle screw needs setting with a couple of electical item's on.
The R5 is basic it doesn't have an ECU it has an AEI unit which has a very basic ingition map on and that is it.
Logged
turbak
150BHP Member
Reply #2 on:
13:24, Sat 27 August 2016 »
Ita normal when the fan start to work...
Logged
Print
Pages: [
1
« previous
next »
RENAULT5GTTURBO.COM
TECHNICAL ISSUES
Renault 5 GT Turbo
