Author Topic: Clio 172 engine In gtt  (Read 3879 times)
Home built turbo
« on: 10:46, Mon 30 September 2013 »
Hi guys any help appreciated I'm gonna put a 172 2.0 in my 5 what clutch is needed to mate 2.0 on the gtt box I have read the advice on the how to page but don't understand
Also thanks lads
Ben
Re: Clio 172 engine In gtt
« Reply #1 on: 17:42, Wed 13 November 2013 »
Also thanks lads
Ben
Assume you may have sorted this now seeing as post was september but Ill answer anyway :-)
Std clio 172 clutch is fine if your sticking with N/A conversion if your going turbo then I recomend a paddle setup fitted,in order for the box to mate up fine you will need to remove both the front and rear gearbox locating lugs to the block otherwise you will be in trouble.
If you need anymore help doing this let me know as I done this conversion a few years back so know a bit about it :-)
« Last Edit: 17:46, Wed 13 November 2013 by James5 »
Home built turbo
« Reply #2 on: 23:01, Tue 19 November 2013 »
Thanks for reply I'm looking at running rebuilt standard engine on 1.9 mm gasket. Turbo low boost approx 245 bhp what couch should I get could I just leave the standard one I only do a few miles.
I may need help am just getting started what's it like in the 5 with this conversation
Cheers bud
« Reply #3 on: 18:15, Sat 23 November 2013 »
Cheers bud
You can run the std 172 engine on turbo fine but with the higher comp you will be limited to say 7psi of max boost this will still be quick if you want more boost the compression really needs to come down,
Ref what the conversion is like I done the n/a conversion and pulled it out after 100miles and went back to a tuned C1J as I missed the turbo LOL  I ended up doing a year or so later an F7p foully forged turbo conversion and that was rapid.
woznaldo
« Reply #4 on: 21:32, Tue 24 December 2013 »
Please correct me if I am wrong, but I believe if you fit a RS Clio 197 Head to the 172/182 Block you will get a lower compression ratio. I'm sure I read that in a Retro Cars or Performance French Cars mag? It's a better head for flow too.
Love 5\'s so much I took mine to Oz to scare some V8s
