Author Topic: B18ft pressure test  (Read 2520 times)
B18ft pressure test
« on: 09:56, Mon 01 July 2013 »
Im getting 150, 90, 100, 150.
This means that its popped between cylinders 2 and 3 right?
Im also super heating the coolant, but not sure if im actually running it through the cylinders.
Cheers
Mark
Re: B18ft pressure test
« Reply #1 on: 19:43, Mon 01 July 2013 »
That doesn't look like a good sign I'm afraid. Definitely something wrong there.
« Reply #2 on: 20:04, Tue 02 July 2013 »
Sounds like poss gasket issue mate if you heating water up quickly and low on compression
