Author Topic: turbo vacuum  (Read 2374 times)
R5gttDJ
turbo vacuum
« on: 13:43, Thu 27 June 2013 »
Is there any way to judge what boost my turbo is at without actually driving it on the road and looking at gauge?
i.e  is the pressure the vacuum the gauge shows similar to what boost its at?
Thanks
Re: turbo vacuum
« Reply #1 on: 20:47, Thu 27 June 2013 »
The engine's vacuum will always stay the same when adjusting boost pressure as it's not part of the turbo system.
You can put a pump onto the actuator and see what pressure it opens the waste gate at. other than that, it's going to be a spin around the block,
R5gttDJ
Re: turbo vacuum
« Reply #2 on: 13:48, Fri 28 June 2013 »
ok thanks mate
