Author Topic: Will gt brake discs fit campus  (Read 2394 times)
« on: 14:26, Fri 21 June 2013 »
As title, with this new engine i can really feel that the brakes arent up to it.
Do the gt turbos have the same calipers just different discs?
Cheers
Mark
Re: Will gt brake discs fit campus
« Reply #1 on: 09:11, Thu 01 August 2013 »
I think the calipers for the GTT are different as vented disc's if you can replace the entire hub from a GTT with GTT caliper and disc you may even be able to pick up cheaper clio valver setup which have better / bigger wheel bearing's in.
« Reply #2 on: 22:57, Tue 06 August 2013 »
Yeah i want the hubs ideally, cus i think ill need some gt shocks aswell.
Maybe thats the way forward
