Author Topic: Renault 5 GT Fuel issue  (Read 3140 times)
asht0n5
« on: 23:56, Mon 27 May 2013 »
Evening,
I have recently bought a 1988 Renault 5 GT, I knew the car had some heating problems and I have changed the head and fitted a new head gasket and water pump and all is ok.
The problem i have now is with fuel, sometimes fuel will pump nicely into the carb by itself but then it will just stop.  The car did sit for 8 years before I bought it so I was thinking of replacing the fuel pump and fuel filter.
Any other ideas would be welcome :)
Cheers Alan
Re: Renault 5 GT Fuel issue
« Reply #1 on: 13:06, Tue 28 May 2013 »
It might be a failing fuel pump, it could also be dodgy wiring.
Try attaching 12v direct to the fuel pump, if it spins fine without pausing or hesitation maybe there is a dodgy wire somewhere.
