Author Topic: afr readings in the 10's on light throttle  (Read 3370 times)
Jermaine1162
« on: 21:03, Mon 13 May 2013 »
My afr reading at light throttle are in the 10's how do I make it leaner.
At wot is around 11.9-12.2
Idle is 14-14.2
Re: afr readings in the 10's on light throttle
« Reply #1 on: 20:35, Tue 14 May 2013 »
Whats your carb spec?
Jermaine1162
« Reply #2 on: 21:55, Tue 14 May 2013 »
I have a standard main jet
1.00 1st stage
1.37 2nd stage
O.9 air corrector
I was thinking of taking my 1st stage down to 0.9
« Reply #3 on: 18:08, Wed 15 May 2013 »
Quote from: "Jermaine1162"
1.00 1st stage
1.37 2nd stage
O.9 air corrector
What boost that set for? Might be worth reducing the ac jet
Have you set the acc pump jet up correctly, this can cause it to go rich under light throttle
