Author Topic: B18FT fuel pump  (Read 1732 times)
B18FT fuel pump
« on: 23:44, Wed 01 May 2013 »
Does anyone know if the fuel pump on the b18ft has the same sandwich plate as on the F2N? This plate seems to just be there as a spacer and was the source of my oil leak which I have now sorted where I managed to fit the gasket on the wrong side of the plate.
It looked like it needed 2 gaskets - one either side of the sandwich plate to make a proper seal between the pump and the head and now as a result the plunger is fractionally further from the cam lobe it operates on. My question is what would happen if that spacer was removed altogether? Why is it there at all? There would be more travel on the plunger but what would happen? I'm not planning on doing this before anyone asks, just wondered after looking at it the other day.
Re: B18FT fuel pump
« Reply #1 on: 10:34, Thu 02 May 2013 »
the spacer in question... may not technically be called a sandwich plate!
