Welcome,
Guest
. Please
login
or
register
03:58, Sun 26 June 2022
Home
Help
Search
Login
Register
RENAULT5GTTURBO.COM
TECHNICAL ISSUES
Renault 5 GT Turbo
Lowering springs?
« previous
next »
Print
Pages: [
1
Author
Topic: Lowering springs? (Read 3872 times)
200BHP Senior Member
Lowering springs?
on:
21:08, Mon 01 April 2013 »
Hi guys, ive got a campus that i wanna drop as low as i can really.
First question is, are the 1.7, 1.4 and 1.1 springs all the same or are they stiffer, stronger the bigger and heavier the engine?
With that in mind, could i get 1.1 springs and fit them expecting a lower drop as there is more weight on them?
http://www.ebay.co.uk/itm/RENAULT-5-Mk2 ... 35b48428b7
1.1 springs 40mm drop
http://www.ebay.co.uk/itm/RENAULT-5-Mk2 ... 4cf97742f5
1.4 springs 40mm drop
http://www.ebay.co.uk/itm/Renault-5-1-7 ... 53ed1f6f72
1.7 springs 50mm drop.
I was considering cutting the springs, but at this price ill do it properly.
Logged
Re: Lowering springs?
Reply #1 on:
19:11, Thu 04 April 2013 »
Are the gt turbo springs the same as the campus? cus theres some 60mm drop springs available
Logged
Global Moderator
Reply #2 on:
21:10, Thu 04 April 2013 »
Quote from: "sparkysparks"
They might not be.
The Phase 2 spring are shorter because of the camber adjusting plate at the top of the strut, Phase 1 springs might be the same size?
I can't think were you would get the measurements from.
Logged
Reply #3 on:
22:59, Thu 04 April 2013 »
Its hard to see and test without buying them all and finding out.
I think if they fit the same way as the campus springs as in the bottom coil is tapered off then ill be ok with gt turbo springs, and they should be stiffer
Logged
Print
Pages: [
1
« previous
next »
RENAULT5GTTURBO.COM
TECHNICAL ISSUES
Renault 5 GT Turbo
Lowering springs?
