Author Topic: Time for a rebuild?  (Read 6463 times)
SCOOBY DREW
Time for a rebuild?
« on: 13:31, Mon 18 February 2013 »
Hello all,
I am not a frequent poster on the forum, but after a little bit of advice pleeeeaaassseeee.....
Could be a sad time for my R5 Turbo.
A crack in the rad about 6 months ago, obviously made me put a new one on.  Car didn't overheat.  As the summer is coming I am putting her back on the road, but now there is a leak from the head out the side of the head.  Looks the sealant has split.  Would people think that the head has cracked?
I know very little about the R5 a part from the work I have done on her over the last 3 years....  It's an H reg by the way....
Any suggestions, positive or otherwise?
Thanks all for reading my woes.
Re: Time for a rebuild?
« Reply #1 on: 15:26, Mon 18 February 2013 »
Quote from: "SCOOBY DREW"
Hello all,
When you say leak from the side of the head do you mean were the blanking plate is or the water pump end?? get a pic of it up matey I will see if I can help you out
SCOOBY DREW
« Reply #2 on: 17:03, Mon 18 February 2013 »
I will try and get a picture tomorrow, but on the right hand side of the block as you face car. Think that is where the blanking plate is...
SCOOBY DREW
« Reply #3 on: 17:05, Mon 18 February 2013 »
Not the pump side...
Sorry meant to say thanks. :)
« Reply #4 on: 17:21, Mon 18 February 2013 »
There is a blanking plate there, six bolts hold it on IIRC.
You might be lucky and it just needs a new gasket (or sealant works just as well to be honest...) but be carefull with the bolts though, the threads have a nasty habit of messing up.
SCOOBY DREW
« Reply #5 on: 17:51, Mon 18 February 2013 »
It is that area and I picked some old sealant off around the leak. Will have a look tomorrow. Thanks for the advice. Lets hope. :)
SCOOBY DREW
« Reply #6 on: 14:25, Wed 20 February 2013 »
Im a little unsure how to put a picture on here, but I can confirm that it is the blanking plate side of the engine.  Therefore do we think that it could just be the gasket?
What is this gasket called, so that I can get another one.  Thanks Again....
« Reply #7 on: 17:05, Wed 20 February 2013 »
It's this item here.
http://www.cgbmotorsport.net/cylinder-h ... -183-p.asp
For a quick fix (...or a more permanent one in my case  :lol: ) silicone sealant works just as well.
SCOOBY DREW
« Reply #8 on: 17:10, Wed 20 February 2013 »
Lol. Thanks for your help. That's my Thursday morning booked then.
« Reply #9 on: 08:23, Thu 21 February 2013 »
 :lol: Will only take you a few mins make sure you clean bot the plate and head surface up to make sure nothing interfers with the mating surfaces
SCOOBY DREW
« Reply #10 on: 11:13, Thu 07 March 2013 »
Although, not 100% relevant to my posts above, could someone have a look at these photos
http://s1308.beta.photobucket.com/user/ ... 8990450953
There are three on here, if I have uploaded correctly, and tell me what the circular part is.  Its all located by the back of the block, below the carb.
Thanks All.....
« Reply #11 on: 22:03, Thu 07 March 2013 »
It looks like your pointing at the inlet manifold?
There are identical circles at each end of the inlet manifold. They don't do anything as far as I know, I think there just cast that way or they might be plugged. There is coolant flowing through the inlet manifold if you still use the standard setup.
SCOOBY DREW
« Reply #12 on: 09:11, Fri 08 March 2013 »
Would it therefore be fair to say, that if water is leaking from here, then this is not a good sign then?
« Reply #13 on: 09:28, Fri 08 March 2013 »
They must be plugged there then.
You don't 'need' the coolant running through there, I personally haven't got the coolant running through the inlet manifold.
You could either attempt to re seal the plug, replace the inlet manifold or just bypass the coolant.
SCOOBY DREW
« Reply #14 on: 09:36, Fri 08 March 2013 »
At least this does not seem as bad as I thought.
I will see if I can find a bung (sure the original one must be somewhere)
Failing that is there a guide on redirecting the cooling?  What are the pros and cons of this?
Thanks
