Author Topic: gearbox swapping parts  (Read 3850 times)
NemesisGTR
« on: 03:51, Fri 11 January 2013 »
I got two gearboxes here with both a different problem, one has got a problem on the primary axle (bearing) and the otherone has a loose crown wheel in the differential,
Now i want to make one good box, is this poss?
How do i open these boxes?
thnx
FB= Hans Macken
NemesisGTR
Re: gearbox swapping parts
« Reply #1 on: 14:26, Tue 15 January 2013 »
Nobody any good advice on this?
FB= Hans Macken
R5_FIN
« Reply #2 on: 15:06, Wed 16 January 2013 »
You should have no problem building one good box out of those two if they are the same type. Keep in mind that there are different JB3 transmissions available, check the type codes carefully.
I would suggest that you get for example the Haynes manual, it has very good instructions on disassembling/assembling the gearbox.
First you need to remove the 5th gear gears and then you are able to open the box. If it doesn't open easily, try engaging different gears. If I remember correctly, you need to have it on certain gear for it to open easily. Can't remember which one it was.
I have the manual so I can give you exact instructions if you want but I strongly suggest on getting the manual yourself. The gearbox is full of small pieces that can come of when you open it. At least that has happened to me...
« Reply #3 on: 16:05, Wed 16 January 2013 »
Beware which Haynes manual you get, the version I have (it's dark green) has no information at all on the gearbox.
NemesisGTR
« Reply #4 on: 16:23, Thu 17 January 2013 »
ok, i got the green one also and find nothing about  gearbox disassembling...
Can you maybe scan the p‚ges and post them here? please :-)
FB= Hans Macken
R5_FIN
« Reply #5 on: 18:14, Mon 21 January 2013 »
Yes, I can scan them, I need to do it at work but I'll try to get it done this week.
NemesisGTR
« Reply #6 on: 13:18, Thu 24 January 2013 »
Quote from: "R5_FIN"
Thanks!!!
FB= Hans Macken
R5_FIN
« Reply #7 on: 14:54, Thu 24 January 2013 »
Hi, I got it scanned. It's a PDF so I can't really post it here. I can send it to you by email, if that's okay?
NemesisGTR
« Reply #8 on: 06:06, Fri 25 January 2013 »
ok perfect!
FB= Hans Macken
