Author Topic: My Phase 2 GTT  (Read 86653 times)
« Reply #135 on: 00:43, Fri 11 April 2008 »
Yes i did know about the centre vents ;)
I'm hoping to get some forged pistons now so i'll be cancelling my order tomorrow :)
« Reply #136 on: 13:48, Fri 11 April 2008 »
Quote from: "GTTBoy"
Nice one..   keep us posted how it goes  8)
H150GTT
« Reply #137 on: 15:48, Fri 11 April 2008 »
Sorry to hear about the trouble..
Once you get the new parts in front of you it will be like christmas all over again lol..  Just be dyin to get at it and get it running again..
Did you consider the steel liner option?
I regret not going for the std compression forgies for my car.. You getting the wossner ones from andy?
Gud luck with the rebuild!
Regards
W
« Reply #138 on: 17:52, Fri 11 April 2008 »
I will be using Wossner yes, i have some lower comp ones in the pipeline at the moment from a member on RTOC (hopefully) but if they don't come to anything i'll go standard comp & new from Andy @ BB, the used ones have only done a few pod runs & the guy is going to get them out & check them over before committing to selling them :)
Steel liners i won't bother with, i hope it doesn't come back to bite me in the arse though :)
« Reply #139 on: 18:20, Fri 11 April 2008 »
So many mixed views on the forged pistons and steel liners combo.
« Reply #140 on: 18:58, Fri 11 April 2008 »
I've got wossner low comp forged items in mine, last time i checked they were a bit sooty but in one piece.  8)
I've got the previous owner to thank for those.
« Reply #141 on: 20:29, Thu 17 April 2008 »
Is yours very noisey from cold ?
Do the pistons rattle alot till the car is warm i mean ?
Should have the pistons tomorro or sat i hope, then it's rebuild time :)
More boost this time as well!!
« Reply #142 on: 08:42, Fri 18 April 2008 »
I've noticed lately it is very noisy when cold but i think the valve cleareances need checking again i've done about 8'000miles since i last set them.
But as far as i remember it's always been noisy when cold.
« Reply #143 on: 10:09, Fri 18 April 2008 »
I think forged pistons do untill they warm up.
H150GTT
« Reply #144 on: 10:45, Fri 18 April 2008 »
Really??  Mine seem the same as the normal pistons..  Maybe mine havnt been run in properly yet or something. Noticed the tapet noise more with the uprated springs with my engine..
Whats boost you thinking off now  :D ??
« Reply #145 on: 13:26, Fri 18 April 2008 »
Well i'm going to run either a little retard or lots of octane booster & get a stethescope to listen for det, hopefully get 25psi manifold out of her for pod, stick to 21psi day to day, i picked up a campus filler neck today so i can ditch the aux tank, plus i also picked up some 14x 6 1/2 j clio rims for my mickey thompson drag tyres  :twisted:
« Reply #146 on: 16:40, Fri 18 April 2008 »
 Sounds awesome   8)   bet u cant wait to get it all up and running and flying again  :D good luck with it.
« Reply #147 on: 18:45, Fri 18 April 2008 »
For sure, i just ripped the aux tank out & fitted a campus filler neck, pistons won't be here till Monday but i may rip the engine out over the weekend & get it on the stand ready to fit them, need to fit the clutch anyway :)
Then Monday i'll order the M/T drag tyres... another £300   :roll:
Goran
    • http://www.bhrenaultclub.com
« Reply #148 on: 08:03, Tue 22 April 2008 »
Bad luck Steve  :( but as I can see, you're all right by now and making progress towards an even better GTT... :D
Wish you good look this time around!!  :wink:
« Reply #149 on: 18:11, Tue 22 April 2008 »
Got the pistons yesterday & the tyres today, just need to get around to fitting the pistons, need some new liner seals 1st & wiat for my cylinder hone kit to turn up.
They were a real pain in the arse to fit, had to go to 2 different tyre fitters :)
