Author Topic: Actuator settings  (Read 1958 times)
Home built turbo
Actuator settings
« on: 20:35, Sun 25 November 2012 »
Hi guys How do I adjust my actuator for good boost as I seem to have very little ?  :cry:
Re: Actuator settings
« Reply #1 on: 10:20, Mon 26 November 2012 »
Quote from: "Home built turbo"
You need to shorten the length of the actuator arm, a couple of turn's will increase boost pressure undo the lock nut and turn the actuator rod arm.  Just becareful you need to make sure you are fueling enough for increased boost pressure.
Home built turbo
« Reply #2 on: 17:00, Mon 26 November 2012 »
Am gonna take it some where I think i turd it and didnt do much well i coulnt tell I don't want to mess it up has any one used any dyno centres in Suffolk/essex I'm thinking of taking it to ra electrics in Colchester is ment to be good ?
