Author Topic: Low boost  (Read 2664 times)
Home built turbo
Low boost
« on: 17:14, Sun 25 November 2012 »
Hi all I took my 5 out after rebuild bad fully rebuilt turbo is like new it just doesn't seem to boost the dump valve goes but the in dash boost gage goes to under half ! Would the actuator be set low or what guys?
Home built turbo
Re: Low boost
« Reply #1 on: 17:20, Sun 25 November 2012 »
Also my rev gage has stopped working so no telling what rev I'm at I have in car boost controll but that doesnt seem to do anything?
Re: Low boost
« Reply #2 on: 18:40, Sun 25 November 2012 »
Quote from: "Home built turbo"
Sounds like the actuator needs more preload, simple thing to fix
Word of wisdom, remove the in-car boost controller there the worse thing on the plant
Home built turbo
Re: Low boost
« Reply #3 on: 19:01, Sun 25 November 2012 »
There is yellow paint on the nut do I just turn it ?
Re: Low boost
« Reply #4 on: 18:30, Mon 26 November 2012 »
Loosen nut the turn the part on the end so it shortens the rod, make sure you pull eyelet off the wastegate arm first them do it
