Author Topic: 5 gearbox swap?  (Read 2309 times)
al79five
5 gearbox swap?
« on: 10:22, Sat 24 November 2012 »
Hi any one got any idea if i can swap my auto box for a manual gearbox is the crankshaft the same? and will i need to change the clutch???
Re: 5 gearbox swap?
« Reply #1 on: 11:02, Sat 24 November 2012 »
Quote from: "al79five"
Yes its possible to change from auto box to manual, i've done it before buts abit more complex than just swaping the box.
To do it you will need
-gearbox
-flywheel
-clutch
-gearbox mounts
-driveshafts
-gearstick and rod
-clutch pedal
-clutch cable
You also need to mod the wiring abit but thats not a hard job to do
al79five
Re: 5 gearbox swap?
« Reply #2 on: 15:19, Sat 24 November 2012 »
thanks for your help what I was planing is that I have been offered a parts donar part for a replacement engine but its a auto and mine is a manual so was after info as to if the engine of the auto would mate with my manual box also the donar is a 1.4 mine is a 1.1 any problems with that?
Re: 5 gearbox swap?
« Reply #3 on: 19:05, Sat 24 November 2012 »
You'll be able to bolt a manual box to the auto engine thats no problem, crak bolt pattern is all the same
