Author Topic: Boost  (Read 3248 times)
Home built turbo
Boost
« on: 21:19, Tue 20 November 2012 »
Any advice on boost pressure settings for t25 stage 4 has forged bottom end so could take a bit not to sure what to set it up to any advice would be appreciate
Re: Boost
« Reply #1 on: 14:05, Wed 21 November 2012 »
Before you increase boost pressure do you have a decent wideband kit so you can monitor AFR's??
Home built turbo
Re: Boost
« Reply #2 on: 22:17, Wed 21 November 2012 »
I will have Ill set on dyno that reads air file ratios I don't have a in car one I could get one what boost will this turbo run?
Re: Boost
« Reply #3 on: 22:36, Wed 21 November 2012 »
Quote from: "Home built turbo"
Who made it and what's been done to it?
'Stage 4' could mean anything, varying from tuner to tuner.
Home built turbo
Re: Boost
« Reply #4 on: 11:00, Thu 22 November 2012 »
Has ceramic wheel 360 bearings upgrade stagerd seal upgrade turbo was built at ra designs I built engine
Re: Boost
« Reply #5 on: 15:54, Thu 22 November 2012 »
If its a good full T25 then around the 20-25psi is possible but will be able to tell more with the exact spec of it
What cam you got in the engine too?
Home built turbo
Re: Boost
« Reply #6 on: 19:08, Sun 25 November 2012 »
How much can I adjust the actuator is hardly boosting as it is
Re: Boost
« Reply #7 on: 10:21, Mon 26 November 2012 »
See other thread you posted I have responded on there but if the actuator is not allowing anymore boost you may have to replace the actuator or run a blled valve to get the boost level you are after
