Author Topic: Computer module vacume pipe  (Read 2583 times)
Home built turbo
« on: 16:28, Sun 18 November 2012 »
Hi all can someone look to c where the vacume pipe on computer module ( pipe near coil) goes to as mine is disconnected
Re: Computer module vacume pipe
« Reply #1 on: 16:52, Sun 18 November 2012 »
Quote from: "Home built turbo"
It will go to the inlet manifold just below the carb base there will be a small brass connector
Home built turbo
« Reply #2 on: 16:55, Sun 18 November 2012 »
Cheers mate did u c my post bout no spark ?
« Reply #3 on: 22:49, Sun 18 November 2012 »
Cheers mate did u c my post about no spark ?
The disconnected pipe would not cause the AEI unit not to spark, so that's not related.
It is an air leak though, so best connecting it up securely.
Home built turbo
« Reply #4 on: 21:24, Tue 20 November 2012 »
Was just curled up inside the cover don't no why it's been removed
