Author Topic: No spark  (Read 4120 times)
Home built turbo
No spark
« on: 15:16, Sun 18 November 2012 »
Hi am new to this site iv just completed a home built r5 was running sweet turned it off and when to start again and no spark not even from king lead I got new every thing plugs etc with build is this the coil that has packed up as I didn't touch anything and it broke not too clued up on electrics help me some one
Re: No spark
« Reply #1 on: 17:30, Sun 18 November 2012 »
Check your TDC lead to make sure its not broke anywhere and the plug is in good condition, also check the relay next to the AEI unit maybe thats at fault. You cana easily bridge that out to see if it works
Home built turbo
Re: No spark
« Reply #2 on: 17:42, Sun 18 November 2012 »
Iv checked tdc wire is fine is there a fuse for the coil thanks mate
Re: No spark
« Reply #3 on: 18:36, Sun 18 November 2012 »
Quote from: "Home built turbo"
No fuse for it, only the relay that sitsnext to it. The relays only there for the over boost switch really so if your not using that its not really needed.
Check if you got power going to the AEI unit, its the yellow wire on the 3pin plug at the bottom
Home built turbo
Re: No spark
« Reply #4 on: 19:54, Sun 18 November 2012 »
Thanks mate I will do that
Home built turbo
Re: No spark
« Reply #5 on: 21:12, Tue 20 November 2012 »
Tested for power eairler has 12 v at coil and 1 something if u put the king lead on and test end of that ,so am hoping a new king lead will solve this ,think I got one some where I couldn't see that yellow wire?
Home built turbo
Re: No spark
« Reply #6 on: 13:00, Thu 22 November 2012 »
Was the king lead that had gone down sparking as should
