Author Topic: fueltank leak  (Read 2829 times)
NemesisGTR
fueltank leak
« on: 03:51, Sun 04 November 2012 »
Everything is up and running, the car responds well, now running it in... i ll post pics soon!
But Now i also got another f*cking problem, my fueltank is leaking on the side where that yellow plug is sitting, any ideas on solving this????
Grtz!!!
FB= Hans Macken
Re: fueltank leak
« Reply #1 on: 10:43, Sun 04 November 2012 »
Sealant. Anything that's resistant to solvents otherwise it will just peel off again.
It's a bit of a tight squeeze, ideally the tank should come off for better access.
Re: fueltank leak
« Reply #2 on: 14:16, Mon 05 November 2012 »
As Ash suggests anything that is fuel resisit will be fine, I done a couple now and to be honest just use a blunt kitchen knife or even a wall scrapper to fill the hole and make sure covered.  Get as much in there as you can and do it when the tank is pretty empty leave it to cure properly for say 24hr's or long dependant on outside temp's
NemesisGTR
Re: fueltank leak
« Reply #3 on: 02:04, Wed 07 November 2012 »
ok thnx fella's!!!
FB= Hans Macken
NemesisGTR
Re: fueltank leak
« Reply #4 on: 01:36, Thu 08 November 2012 »
You know any good brands? i got special 2 component bison here...
FB= Hans Macken
