Author Topic: clio williams gearbox  (Read 2108 times)
NemesisGTR
« on: 01:52, Wed 24 October 2012 »
Hi, is the williams gearbox a good alternative for the gtt? or what is a good alt?
Please some info...
Grtz
FB= Hans Macken
Re: clio williams gearbox
« Reply #1 on: 07:59, Wed 24 October 2012 »
Willy box will fit but your problem will be speedo pick up.
NemesisGTR
« Reply #2 on: 12:15, Wed 24 October 2012 »
thats no issue , got that fixed with the electronic speedopick up from the modern clio's, also 3 wires.
Is it stronger, the willi box? and the ratios? will i run lower rpm on highway in 5th?
FB= Hans Macken
« Reply #3 on: 16:03, Wed 24 October 2012 »
Quote from: "NemesisGTR"
Its not really any stronger, ratios are shorter so you will have higher rpm for same mph as a 5 box
I personally would leave the 5 gt box in with the C1J
NemesisGTR
« Reply #4 on: 01:18, Thu 25 October 2012 »
ok thnx, then i will put in a gtt box :-)))
FB= Hans Macken
