Author Topic: break down :(  (Read 5257 times)
ecosteve
    • http://www.flickr.com/photos/ecosteve1990/
break down :(
« on: 21:26, Tue 16 October 2012 »
Hi guys.   my 5gt has a problem.  i think its fuel pump relay but il ask for your opinions.   few weeks ago my car decided to cut out and wouldnt start again.  just kept turning over but wouldnt catch. i took the earth off the battery and replaced and it started fine.  250 miles later (today) im driving normaly at 30 and it cuts out.  i took earth off and on and no change.   when it was turning over i could not hear fuel pump.   i took all fuses out and replaced them all seemd ok there. i tapped all the relays.  tried it again and could hear fuel pump and it started fine.   any ideas as its my daily driver while im rebuilding my bike
ecosteve
Re: break down :(
« Reply #1 on: 12:33, Wed 17 October 2012 »
Does anybody know which fuse and relay does fuel pump.  thanks
ecosteve
Re: break down :(
« Reply #2 on: 16:47, Wed 17 October 2012 »
Happend agaim today.  yried same as yesterday but no luck.   i saw the turbo timer was on turnd it off and it fired.    can turbo timer stop fuel pump.   i never use it so il just remove it i think
Re: break down :(
« Reply #3 on: 17:15, Wed 17 October 2012 »
It all depends how the turbo timer is wired in, i would say deiconnect it and give it a try. If it still does it remove the fuel pump relay and bridge the plug and test it, if it doesn't cut out then you know its that
ecosteve
Re: break down :(
« Reply #4 on: 21:23, Wed 17 October 2012 »
Thanks mate.  do you know whice relay it is
ecosteve
Re: break down :(
« Reply #5 on: 12:06, Thu 18 October 2012 »
did it today. turnd off timer  and wouldnt start. i lockd and unlokd the car by the fob and it started. its a 1989 do these have imobaliser do you know. nothing seems to be definate in my mind
Re: break down :(
« Reply #6 on: 12:09, Thu 18 October 2012 »
Fuel pump relay is located behind the passenger fuse box it's black about 2"s long by 1" wide says Cartier on it.  To bridge connect the yellow and white wires together for an ignition live or a perm live feed red and white.
ecosteve
Re: break down :(
« Reply #7 on: 12:15, Thu 18 October 2012 »
thanks bud il look when i finish. do you know if there is an imobaliser standard
Re: break down :(
« Reply #8 on: 14:53, Thu 18 October 2012 »
Quote from: "ecosteve"
No immobilisers as standard, poss sounds like something to do with the turbo timer
ecosteve
Re: break down :(
« Reply #9 on: 21:36, Thu 18 October 2012 »
Il have to have a spy on sat as its anoying when i use it daily. Cheers for all the help
ecosteve
Re: break down :(
« Reply #10 on: 17:51, Wed 24 October 2012 »
a quick update. cars still doing this cutting out thing. sometimes when driving other times when its been run and sat for a little bit. any body have any ideas. iv baight a new relay so im hoping that helps if not im clueless
Re: break down :(
« Reply #11 on: 18:18, Wed 24 October 2012 »
Poss sound like relay dieing abit if its not the turbo timer, it is common for the relay to fail with age
Jermaine1162
Re: break down :(
« Reply #12 on: 21:55, Wed 24 October 2012 »
If it is the relay iv got a brand new one from cgb what I payed 50 for u can have it for 35. It's never been used and not needed as my car is getting striped. So if u need any items let me know
ecosteve
Re: break down :(
« Reply #13 on: 11:14, Sat 27 October 2012 »
hi guys il check the relay today and get back to you. if i need it il have it off you pal.   i changed crank postion sensor but no joy.  il clean dizzy up... do these cars have condensers and coils im at a loss with carbs im used to injection
Re: break down :(
« Reply #14 on: 11:28, Sat 27 October 2012 »
The distributor is just there to to distribute the spark, there are no electronic gubbins underneath the cap.
The spark is dealt with electronically via the AEI unit.
