Author Topic: question about fuelpump  (Read 2729 times)
NemesisGTR
« on: 20:18, Sun 07 October 2012 »
Hi,
My fuel pump doesnt work when i turn the ignition on, when i give it 12v true an external 12v suply it works(i just took out my engine due to a clutch problem wich i solved) Should the pump only work when i turn the key to start the engine? i think not... The car stands still for a long period, but i drove it until then, is it possible that the relais just gave in???
Some help here please :-)
Thanks already ;-)
FB= Hans Macken
Re: question about fuelpump
« Reply #1 on: 20:39, Sun 07 October 2012 »
The fuel pump should work when the flywheel turns.
If you think the relay might of failed you can temporarily check by removing the relay and bridging the connection. I forget which wires to bridge now but if you search on the forum it should be easy to find, it's a common fault.
NemesisGTR
« Reply #2 on: 02:50, Mon 08 October 2012 »
ok thanks, is it true that this relais is in the fusebox under the glovecompartment?
FB= Hans Macken
« Reply #3 on: 07:57, Mon 08 October 2012 »
Yes.
It's not actually inserted into the plastic block of relays though, it is clipped on the right hand side towards the back.
« Reply #4 on: 08:49, Mon 08 October 2012 »
Bridge the yellow and white wire's this will give an ignition live or red and white will give a perm live feed.  (white wire is the pump feed wire)
NemesisGTR
« Reply #5 on: 11:18, Mon 08 October 2012 »
ok, thnx guys!!
FB= Hans Macken
