Author Topic: rear bush advice needed asap please :):):):):):)  (Read 3024 times)
ecosteve
    • http://www.flickr.com/photos/ecosteve1990/
« on: 12:45, Tue 02 October 2012 »
hi guys my car faild mot today on rear subframe bushes near and offside. i cant find them anywhere. ramg renault and other motorfactors but all want a part num which i dont have. any help would be great. thanks folks
ecosteve
Re: rear bush advice needed asap please :):):):):):)
« Reply #1 on: 14:29, Tue 02 October 2012 »
or if any body knows bushes that are from other cars that will fit it would help me a great deal
Jeff Ninebar
« Reply #2 on: 12:32, Mon 08 October 2012 »
Do you mean the front engine sub frame wishbone rear bushes?
There are no bushes on the rear sub frame/swing arm as far as I know...
« Reply #3 on: 17:57, Mon 08 October 2012 »
There's bushes in the rear trailing arms on the rear axle but i think there not avaliable anymore, i would double check with someone like Mike @GT Turbo Spares to be sure.
The rear axle on the Clio 16v isn't that for off the same design, wonder if they are the same bushing i there
« Reply #4 on: 08:49, Tue 09 October 2012 »
As you say Mark the 16v is basically the same at the rear just a few mm wider that is it I would have thought the valver bush's would fit
ecosteve
« Reply #5 on: 14:15, Tue 09 October 2012 »
think i found some on ebay. orderd il let you know when they arive. there called radial arm bushes or somthing like
