Author Topic: Gauges  (Read 1474 times)
Kylegtt
Gauges
« on: 00:00, Tue 07 August 2012 »
Alright lads,got some gauges i wanted to wire up.. boost,water temp etc, i wanted to know how everyone has wired theirs up,because i dont want to have too many loose wires and dodgy connections, wanted to do one neat tidy job.. any suggestions..
cheers lads
Yes i still go to school! And had 3 R5\'s..
Re: Gauges
« Reply #1 on: 07:19, Tue 07 August 2012 »
I have my 3 dials fitted where the centre vents used to be.
Switched live - Ignition barrel with an inline fuse.
Earth - I used the steering column mount.
Dim (if yours has the option when you turn the sidelights on) - I tapped into the wire that illuminates the heater dials.
Any other sensor wires will need to connect up under the bonnet so you will need to find a way through the bulkhead.
