Author Topic: O2 sensor fitting  (Read 2584 times)
NemesisGTR
O2 sensor fitting
« on: 16:16, Tue 24 July 2012 »
Hi,
I want to install a wideband kit on my gtt.
Now i would like to know where i have to weld the bung for the o2 sensor, cause on the net i find alot of different places where to fit it.
Please an exact discription with a pic maybe?
Thnx alot in advance and long live the R5GTT !!!!
Grtz
FB= Hans Macken
Re: O2 sensor fitting
« Reply #1 on: 16:45, Tue 24 July 2012 »
Hopefully this works, scroll down to the MB Performance downpipe & you should get some idea ..
viewtopic.php?f=2&t=1259&hilit=m+b+performance&start=20
« Reply #2 on: 21:42, Tue 24 July 2012 »
I would be tempted to move it down the pipe further still.
Mine was roughly in that position, and I damaged my sensor. However, I use the Innovative Motorsports wideband kit which isn't exactly known to be the most reliable.
NemesisGTR
« Reply #3 on: 14:17, Wed 25 July 2012 »
thnx for the response!
I m pretty shure that it is way to close to the turbo, the lenghts i heard where between 16 inches from turbo and up to almost 40 inches, so there s where my doubt is...
And does the sensor need to be angled so it points towards the ex gasses?
Does anyone have a pic of one working good on a cgb downpipe? (i m going to buy the AEM uego failsafe wideband and boostgauge  in one, looks nice!)
http://www.aemelectronics.com/wideband- ... -gauge-84/
grtz
FB= Hans Macken
« Reply #4 on: 19:05, Wed 25 July 2012 »
Have CGB started making downpipes with the threaded inserts?
I live just down the road and he did mention he was going to look into making the larger downpipes.
I have mine angled at about 45 degrees (not vertical nor horizontal, somewhere inbetween) with the lead pointing at the bulkhead.
NemesisGTR
« Reply #5 on: 13:14, Thu 26 July 2012 »
Not that i know of, but i got a new one from them lying here to be fitted, and want to weld a bung first before wrapping and fitting... That's why i would like to know how to place the sensor...
Please can someone give me some accurate fitting instructions?
(Thnx already ash-lee for the good tips)
FB= Hans Macken
NemesisGTR
« Reply #6 on: 03:02, Sun 29 July 2012 »
no one else?
FB= Hans Macken
Itsafrenchthing
« Reply #7 on: 22:27, Mon 20 August 2012 »
ive fitted mine under near the sub frame, most widebands say its best to install between 10 and 2 oclock on the pipe.make sure you calibrate it before you put it in the exhaust for the first time
