Author Topic: suspension legs  (Read 1591 times)
gorde 5
suspension legs
« on: 20:28, Mon 16 July 2012 »
Hi just replaced front legs with new 35mm springs,bearings etc but the camber angle is now too far inwards,used a haynes manual to make sure everything was right,the old legs were cut an shut springs welded to cups by previous owner! its an early phase 2 an was wondering if its meant to have phase one top mount or coil spring cups? no hub damage and wishbone balljoints seem ok,any helpfull advice would be great.
Re: suspension legs
« Reply #1 on: 20:54, Wed 18 July 2012 »
When you fitted new shocks did you match them to the top mounts, phase 1 shocks need phase 1 top mounts and same for phase 2
gorde 5
Re: suspension legs
« Reply #2 on: 20:39, Thu 19 July 2012 »
Yep realised that i have phase 1 top mounts and phase2 struts! ordered new ph2 top mounts from cgb an hopefully that wiil cure that problem,
