Author Topic: new fuel tank fitted  (Read 3089 times)
streakey
« on: 21:37, Wed 11 July 2012 »
Im a new member & I'm havibg a few problems, had to put a new tank in & now the fuel pump isn't working when I try to start it ?
Cheers Neil
Re: new fuel tank fitted
« Reply #1 on: 21:35, Thu 12 July 2012 »
Quote from: "streakey"
Cheers Neil
Have to check, you did connect the pump wiring back up once you refitted pump? Check the wiring incase its not making good contact or a wire has broke
streakey
« Reply #2 on: 22:22, Thu 12 July 2012 »
Thank Mark double checked & the wiring all looks good. The pump was working fine befoe we replaced the tank, could the relay be playing up ?
« Reply #3 on: 22:16, Fri 13 July 2012 »
Worth looping the relay plug out just to see if you can here the pump work
streakey
« Reply #4 on: 21:47, Wed 18 July 2012 »
Thanks Mark the pump wasn't working have ordered a replacement
Cheers Neil  :wink:
« Reply #5 on: 07:42, Tue 24 July 2012 »
Can also be the connector plug if you pulled them apart, maybe replace them or clean them up if the problem persists
