Author Topic: Mixture and idle speed  (Read 1864 times)
DIZZY DAZZLER
« on: 13:31, Tue 10 July 2012 »
Folks what is the ideal idle speed for the CJ1 and what sort of mixture should it be set to at the required idle.
For info mine is idling at 1100rpm at 3.5%, is this micxture too low, should it be more like 4>4.5%.
Re: Mixture and idle speed
« Reply #1 on: 17:12, Tue 10 July 2012 »
Quote from: "DIZZY DAZZLER"
Should be about 850-1000rpm and be around the 2.5-3% ideally
Do you know if anything has been done to your carb?
