Author Topic: new turbo  (Read 2465 times)
R5gttDJ
new turbo
« on: 20:56, Thu 28 June 2012 »
sent my turbo away for a rebuild, turns out to be totally knackered!!!
any advice on the best turbo to get now, Dont want ot too big maybe t25 max, Would prefer a slightly improved t2 to handle a little more boost, or should i just get a recon standard unit
any ideas??
Re: new turbo
« Reply #1 on: 21:12, Thu 28 June 2012 »
If you got a standard engine and don't want too much boost a T2/T25 will do the job
R5gttDJ
Re: new turbo
« Reply #2 on: 21:55, Thu 28 June 2012 »
t2 i'll probs go for, also i was told it was oil starvation that ruined my turbo??
what could be the problem because theres oil pressure?
maybe the oil feed pipe to the turbo is blocked??
any help appreciated. :D
Re: new turbo
« Reply #3 on: 16:42, Fri 29 June 2012 »
Quote from: "R5gttDJ"
How much oil pressure you have though when engine was warm?
R5gttDJ
Re: new turbo
« Reply #4 on: 18:45, Fri 29 June 2012 »
I still use the original pressure gauge on the dash, and everything seemed ok, don't know what pressure it was at however.
Re: new turbo
« Reply #5 on: 21:59, Fri 29 June 2012 »
Even if you have pressure if its not enough pressue it can kill a turbo still, contaminated oil can kill turbos too.
I wouod double check your oil pressure as you don't want to kill a new turbo
R5gttDJ
Re: new turbo
« Reply #6 on: 00:32, Sat 30 June 2012 »
Cool, cheers mate
