Author Topic: Bigger turbo  (Read 3896 times)
stevegtt
Bigger turbo
« on: 14:25, Sat 02 June 2012 »
What's the best turbo to run on my gt apart from the t2 it comes with ?
Re: Bigger turbo
« Reply #1 on: 22:49, Sat 02 June 2012 »
Not the Rover T25's.
I went through a few of these, laggy and not really suitable for high boost (read they just fall apart after a while)
I personally use a GT Tuning's HE5B which is a T25 sized turbo and it's very responsive (i run 22PSI)
Re: Bigger turbo
« Reply #2 on: 23:48, Sat 02 June 2012 »
VNT !
stevegtt
Re: Bigger turbo
« Reply #3 on: 10:49, Sun 03 June 2012 »
What about a t28 turbo ne one running one of them
Re: Bigger turbo
« Reply #4 on: 16:43, Sun 03 June 2012 »
What you got to deside is what boost you want to run, how you want the engine to respond and also whats the spec of your engine already
stevegtt
Re: Bigger turbo
« Reply #5 on: 17:22, Sun 03 June 2012 »
Well thinking about setting it up for track and drag. So if ne one has ne ideas would like to here them.
Re: Bigger turbo
« Reply #6 on: 11:23, Mon 04 June 2012 »
Quote from: "stevegtt"
Whats your engine spec at the moment mate and how much boost would you like to run?
Re: Bigger turbo
« Reply #7 on: 12:05, Mon 04 June 2012 »
I have run t2 , t2.25 , t28 , and VNTs
All about your engine spec , and what boost you want to run as Marky Mark said.
Every turbo has a different characteristic !
stevegtt
Re: Bigger turbo
« Reply #8 on: 21:03, Mon 04 June 2012 »
Well I'm building the engine 1.4 back up so was going to update as I go and just trying to find out what would be best to put in to it ?
Re: Bigger turbo
« Reply #9 on: 12:37, Tue 05 June 2012 »
If you sticking with standard cam then i wouldn't go any bigger than a full T25, maybe go for T25 with T2 rear housing this will be nice and responsive but still be able to flow some boost
stevegtt
Re: Bigger turbo
« Reply #10 on: 17:45, Tue 05 June 2012 »
That sounds good to me thanks.
