Author Topic: gear problem  (Read 1444 times)
karlr5
gear problem
« on: 23:43, Mon 30 April 2012 »
i cant seem to get all gears i.e if i adjust the gear rod i will lose reverse but gain 5th gear and then if i re-adjust i lose 5th and gain reverse,what am i doing wrong adjusting too far?
Re: gear problem
« Reply #1 on: 19:08, Tue 01 May 2012 »
I kept getting this after swapping gear sticks.
The easiest way I found was to do the rod up loosish and bolt the gear stick down finger tight and put it in 4th.
Then lift it up again, undo the rod and put the stick to 4th again. And tighten it up a bit.
Check you can get it into all the gears and nip it all up.
It took a couple of times for me but worked perfectly in the end.
