Author Topic: renault 5 gt running problems  (Read 2699 times)
oldskoolr5
« on: 21:49, Sun 08 April 2012 »
hi guys can anyone help ive just picked up my 6th 5 turbo and as boost kicks in then i let off the cars runs like a bag of nails ie cuts out at junctions and kangeroos down the road please help.
Re: renault 5 gt running problems
« Reply #1 on: 23:21, Sun 08 April 2012 »
Sounds like it could be
a) Leak in inlet manifold.
or
b) Poorly setup carb.
oldskoolr5
« Reply #2 on: 08:40, Mon 09 April 2012 »
hi do you mean gasket's on inlet or air getting in. I haven't had a look at the carb yet but will do today hopefully.
« Reply #3 on: 18:54, Mon 09 April 2012 »
I did. Check the inlet manifold for air leaks. Other one is the carb base gaskets.
Easy check is with wd40 spray it around that area - if it picks up you have a gap ..
« Reply #4 on: 23:19, Mon 09 April 2012 »
Have a look around all the vacuum hoses around the carb first. Could be an easy fix.
I find the hose from the inlett to AEI unit the main one to cause the problems.
oldskoolr5
« Reply #5 on: 16:39, Tue 10 April 2012 »
checked all pipes, working fine, no air leaks
put some carb cleaner down
only starts when at motorway/overtaking speeds then if you leave running for a few minutes it is back to normal until you high rev again
any other suggestions please
thanks
