Author Topic: sump breather?  (Read 2975 times)
karlr5
sump breather?
« on: 23:42, Sun 12 February 2012 »
is the pipe coming from the side of the sump up to the swirl pot really needed? thanks.
Re: sump breather?
« Reply #1 on: 00:04, Mon 13 February 2012 »
I haven't used mine for a long time.
It's not so much a breather, more of a drain for the oil breather swirl pot thing.
Re: sump breather?
« Reply #2 on: 08:26, Mon 13 February 2012 »
As Ash says it's an oil return to sump from the oil sepetator pot above, as it would suggest the oil seperator pot would sepearator the vapout and return the oil to sump.  Alot of peeps would remove pipe and block at the back of the sump like I did.
Sparkie
Re: sump breather?
« Reply #3 on: 22:03, Mon 13 February 2012 »
pull off the breather pot with the car running, and stick your thumb over the pipe that comes up from the sump, wait about 30 secs. i bet the turbo starts smoking....
Re: sump breather?
« Reply #4 on: 22:24, Mon 13 February 2012 »
Quote from: "Sparkie"
30 seconds sounds a little ambitous.
5 years and 40'000 or so miles later and mine still hasn't started smoking.  :?
Re: sump breather?
« Reply #5 on: 09:53, Tue 14 February 2012 »
If the turbo starts smoking from that, I'd be checking the rocker cover breather!
I've never felt any pressure come from the sump return, and seen loads of then plugged up.
bigdur
Re: sump breather?
« Reply #6 on: 21:56, Tue 14 February 2012 »
Mine is plugged.
Sparkie
Re: sump breather?
« Reply #7 on: 00:07, Thu 16 February 2012 »
maybe it was my shady piston rings.... it was a little breathy.  :lol:
Re: sump breather?
« Reply #8 on: 13:11, Thu 16 February 2012 »
with dodgey piston rings use it would be causing pressure through there and out the rocker cover breather as you would be pressuring the sump and pushing all the oil up and out what ever hols go out :lol:
Sparkie
Re: sump breather?
« Reply #9 on: 13:01, Fri 17 February 2012 »
to be fair, it was actually the liners. - i'd worn them into an hourglass shape through overrevving.... :shock:
