Bolted, or riveted onto the sill. Then they pull towards your slightly and then upwards of about 5 clips.
You will almost certainly need a new set of clips if they are the originals as they have probably rusted away.
You can remove the skirts with the arches in place with a bit of fiddling. Removing the front arch might make life easier.
