Author Topic: campus with gtt carb  (Read 3275 times)
synkro
« on: 14:52, Thu 12 January 2012 »
Can anyone please help me with any imformation on swapping  prima campus efi with a gtt carb? I have removed the efi & chucked it in the hedge, but am unsure how to plumb up the gtt carb to get it working. I hope someone can help me out!
Re: campus with gtt carb
« Reply #1 on: 16:49, Thu 12 January 2012 »
Welcome to the site 8)
Is there any reason for binning the EFI, did it fail or anything?
If you put the carb on, looking at the driver's side:
The top spout will be your fuel line.
The spout under that connects to your pressure reference to the fuel pressure regulator. This also connects to the spout on the plastic plenumon top of the carb.
The two at the very base of the carb are for coolant.
Passenger side:
Loop the two spouts on the plenum as you won't need them.
The spout at the base of the carb is usually part of the actuator system so can either be blocked, or I think you could use it for a vacuum gauge if you wanted one.
There's one at the front that points down, this is a fail safe and needs a hose routing down to the front of the gearbox.
I think that's all.
I hope thats some help :)
synkro
« Reply #2 on: 10:42, Fri 13 January 2012 »
Cheers for the answer. So i will need  a fuel pressure regulator then.... As the petrol goes in the top "spout" at the moment and blasts out the inside of the carb. (filled up the intake manifold & caused a hydraulic lock situation!)
« Reply #3 on: 10:45, Fri 13 January 2012 »
Yes you will need a fuel pressure regulator too but its all designed to work with boost, why did you not leave the efi on? Or fit a carb that doesn't work with boost?
synkro
« Reply #4 on: 10:58, Fri 13 January 2012 »
I didnt leave the efi on because it never ran right with it on ever. And i'm using a gtt carb because i had one laying around & due to being skint i will be some how making it work....i hope.
« Reply #5 on: 11:05, Fri 13 January 2012 »
Thats cool mate
danielmk323
« Reply #6 on: 12:47, Fri 13 January 2012 »
Dont want to  hijack but what is the job of the  part that has the lever ting  does fuel come out of the spout near it   ?
« Reply #7 on: 13:14, Fri 13 January 2012 »
Quote from: "danielmk323"
Thats the accelerator pump jet lever, no fuel shouldn't come out of the outlet next to it
danielmk323
« Reply #8 on: 17:30, Fri 13 January 2012 »
Tanks for the help so now i need to fond out y i have some fuel coming out i think fuel reg is the problem
« Reply #9 on: 14:05, Sun 15 January 2012 »
There's a little gasket behind the pump jet, it could be split.
danielmk323
« Reply #10 on: 16:29, Sun 15 January 2012 »
new gasket fit it in all off carb re cheek it has no  splits fpr  next ii think that is split and is  letting fuel  escape from the top port where the inlet vac pipe is and is leaking from the pipe near  the pump jet
