Author Topic: hellppppppppppp ?!?!? ignition  (Read 1783 times)
Sschipps
« on: 13:48, Sun 08 January 2012 »
changed my main jet in carb, went for spin was loads better still abit off in 4th in high boost so i then changed gap on my plugs, tried starting and nothing!! ignition prob sumwhere! that iv obviously done !  :oops:   any ideas? ???  ... wen i try starting it sounds like only firing 1 or 2 cyclinders  :?  cheeeeerss ????
Re: hellppppppppppp ?!?!? ignition
« Reply #1 on: 13:59, Sun 08 January 2012 »
Firstly, change the gap on the spark plugs to the previous measurements. See if that's what upset it.
Check the for obvious aswell, damaged leads etc. Are the leads even fitted back in the correct order?
Sschipps
« Reply #2 on: 14:37, Sun 08 January 2012 »
I did change the gap back. An as far as I kno te leeds are in same place. Done it one at a time. Iv took them of one by one an tuned it over to see if they spark an only one seems to be. But that myt jus be sumin I'm not doin ryt  :?  :(
« Reply #3 on: 16:25, Sun 08 January 2012 »
Use the one lead you have found that sparks. Try all 4 plugs on that lead to rule out the plugs being at fault. Seems unlikely that 3 plugs would fail at the same time but you never know.
